XR200R pilot screw
I have an 2000 XR200R. I took the pilot screw out and it only had a spring around it. Should it also have a washer or a gasket or something?
Try looking up into the hole with a flashlight. You should see the washer. It might just look like it is the bottom of the hole. Bend the end of a paperclip and gently try to pull it out. That is what has happened to me.
