Oil Change
I am sorry but am I mistaken that you must drain your radiator to change the oil on a 2005 KX250F? Also do I which drain plug do I pull because from what I can tell in my manual it shows two on the bottom of the engine....
You must pull both of the plugs out (one is for the tranny the other is for the engine) I believe they are sizes 14mm and 8mm. Becareful on the smaller one though cuz when you tighten it, it won't really stop so it's easy to strip it. You don't have to drain the coolant you will need to take the oil filter cover off though which is located right above the water pump. The manual should have pics (btw, you only do that if you're changing the oil filter)
