oversize or double head gaskets for reduced compression?
Are there any views on the merits of fitting an oversize head gasket to an XR4 to reduce compression? I've had a trawl through the archives, but no mention of this topic. I'm about to fit a Wiseco/Advanced Sleeves 440 kit with a 12.5:1 piston and want to preserve the reliability and reduce the likelihood of overheating. (Yeah yeah, I should have bought the correct piston in the first place....)
Any help is appreciated.
Get the correct piston. I recomment the 11.5:1 piston from THUMPER RACING. It too is made by Wiseco but to their specs.
Otherwise you will be running Race gas or at least a 50/50 blend. A aftermarket cam will lower the compression some due to longer duration.
Cher'o,
Dwight
Cher'o,
Dwight
Yes, sell your piston on Ebay and go with the right one. I run 10:1, but they only make that up to 426cc. Comet does have 2 different gaskets, a steel shim type and a composite type that is thicker, but the difference in compression is minimal.
Dwight And Dale
Thanks for your replies. I know the answers in my head, but am too stubborn to admit that I made a mistake!
Look for an 89mm 12.5:1 piston on ebay shortly.
Use 2 base (cylinder)gaskets or cut your own out of gasket sheet(thicker than stock)...Normaly I raise the compression (on XR600's)by cutting a thinner one.Cheap extra power :cry:
