2005 Husky update preview
Just got some info from Husky, thought you guys would be interested............. Jeff
2005 Preview : Model Updates, Changes
&Improvments
Engine Changes for 2005
Larger DiameterTitanium Valve Stems - Improved Strength and
Valve Seating Metal
Head Gasket -Improved Cooling
Revised Back-up KickStarter System - Improved
Strength (optional equipment onmotocross models)
Stronger Generatoron Enduro
Models - Improved Power Output
Starter Clutch addedto 250s starter system
CNC Hard AnnodizedAluminium
Clutch Basket on 450 - Improved Strength
450 Engine Has NewRebalanced Crankshaft
with Larger Diameter Wrist Pin, NewRoller Bearings, and New
Connecting Rod - Improved Strengthand Less Vibration
Polished Camshaft on250 -
Smoother Operation
Keihin Carburettorwith Redesigned Intakes - Hot/Cold Double
Choke System with"Hot Start" Button
New Intake Cams on250 and TC 450/510 -
Improved Torque
Lighter Crankshafton TC 250 - Improved Throttle Response
Smaller
CrankshaftBearings on TE and TC 250 - Improved Throttle
Response New Intake
Duct onTE 250 (same as TC '04) - Improved Air Flow
Chassis Modificationsfor 2005
Improved
SuspensionValving
Shock Absorbers withNew Sealing Rings and Lighter Reservoir
to ImproveEfficiency
Lower Shock LinkageNow Utilizes a Roller Bearing and All
Needle Bearings in theRear Suspension are Longer on TE
models - Lower Friction andImproved Durability
Solid Rear BrakeRotor - Improved
Pad Life TE Models
have Axleswith Clip for Rapid Removal
TC Models feature240mm Diameter Rear Disc
Brake and Smaller Brembo Caliperand Forged Support
TE Models featureShock
Absorbers with Bottom-out Spring plus New SealingRings and
New Reservoir Tank
Radiator OverflowTank (TE models)
"Holeshot"Starter Hook on Forks (TC models)
New Front BrakeMaster
Cylinder
Electrical SystemUpdates for 2005
Generator withImproved Battery Recharging Circuit on
TE Models. Timing at
0 RPMModified to Ease Starting
Solid 1-pieceFlywheel on TC 450/510
New CPU withThrottle Position Sensor
and Gear Sensor
Switch on Clutch toPrevent Accidental Starting
Bodywork Changes for2005
New Bodywork andFuel
Tank derived from TE 510 Centennial Model (new rearfender,
side panels, shrouds and tank)
New HeadlightFairing (TE models)
New Front NumberPlate (TC models)
Front FenderReinforcement
Plastic Frame Guards
That one is interesting as the 04 are SS :cry:
Ahh... but does the '05 body work fit straight onto an '04?
More importantly, can you buy the alloy tank (and fuel cap) off the Centennial and how much?
I got my '04 TE250 in late July '03. I won't be having an '05 but I don't think you will have to wait too much longer...
I just went to Husky usa web site and they don't have anything on the 05's. Anyone know the MSRP on the new TE450? What are the differences b/t TE/TC?
