Need help quick! (please!)
I got around to putting in my hotcam today, which means reshimming also... Everythings good but I have a Q. the stock intake shims were .170 and .175. both clearances were .004
The exhausts were- left- .009 right-.012 I need to know what shims to use where. The manual gave me a forumla but I didn't keep track of what side the stock shims were on. the stock exhaust shims didnt have #s on them? so what are they?
decomp was at .018
please help me figure out what shims i need?
decomp was at .018
You only need one intake shim, a 1.65. take the 1.7 and put it where the 1.75 shim was and that one will be good.
You need to mic up the exhaust shims so you know what you have in there, then you can figure out what you need.
14901-MBB-000 .0472in 1.20mm
14902-MBB-000 .0482in 1.225mm
14903-MBB-000 .0492in 1.25mm
14904-MBB-000 .0502in 1.275mm
14905-MBB-000 .0512in 1.30mm
14906-MBB-000 .0522in 1.325mm
14907-MBB-000 .0531in 1.35mm
14908-MBB-000 .0541in 1.375mm
14909-MBB-000 .0551in 1.40mm
14910-MBB-000 .0561in 1.425mm
14911-MBB-000 .0571in 1.45mm
14912-MBB-000 .0581in 1.475mm
14913-MBB-000 .0591in 1.50mm
14914-MBB-000 .0600in 1.525mm
14915-MBB-000 .0610in 1.55mm
14916-MBB-000 .0620in 1.575mm
14917-MBB-000 .0630in 1.60mm
14918-MBB-000 .0640in 1.625mm
14919-MBB-000 .0650in 1.65mm
14920-MBB-000 .0659in 1.675mm
14921-MBB-000 .0669in 1.70mm
14922-MBB-000 .0679in 1.725mm
14923-MBB-000 .0689in 1.75mm
14924-MBB-000 .0699in 1.775mm
14925-MBB-000 .0709in 1.80mm
14926-MBB-000 .0719in 1.825mm
14927-MBB-000 .0728in 1.85mm
14928-MBB-000 .0738in 1.875mm
14929-MBB-000 .0748in 1.90mm
14930-MBB-000 .0758in 1.925mm
14931-MBB-000 .0768in 1.95mm
14932-MBB-000 .0778in 1.975mm
14933-MBB-000 .0787in 2.00mm
14934-MBB-000 .0797in 2.025mm
14935-MBB-000 .0807in 2.05mm
14936-MBB-000 .0817in 2.075mm
14937-MBB-000 .0827in 2.10mm
14938-MBB-000 .0837in 2.125mm
14939-MBB-000 .0846in 2.15mm
14940-MBB-000 .0856in 2.175mm
14941-MBB-000 .0866in 2.20mm
14942-MBB-000 .0876in 2.225mm
14943-MBB-000 .0886in 2.25mm
14944-MBB-000 .0896in 2.275mm
14945-MBB-000 .0906in 2.30mm
14946-MBB-000 .0915in 2.325mm
14947-MBB-000 .0925in 2.35mm
14948-MBB-000 .0935in 2.375mm
14949-MBB-000 .0945in 2.40mm
14950-MBB-000 .0955in 2.425mm
14951-MBB-000 .0965in 2.45mm
14952-MEB-000 .0974in 2.475mm
14953-MEB-000 .0984in 2.50mm
14954-MEB-000 .0994in 2.525mm
14955-MEB-000 .1004in 2.55mm
14956-MEB-000 .1014in 2.575mm
14957-MEB-000 .1024in 2.60mm
14958-MEB-000 .1033in 2.625mm
14959-MEB-000 .1043in 2.65mm
14960-MEB-000 .1053in 2.675mm
14961-MEB-000 .1063in 2.70mm
14962-MEB-000 .1073in 2.725mm
14963-MEB-000 .1083in 2.75mm
14964-MEB-000 .1093in 2.775mm
14965-MEB-000 .1102in 2.80mm
14966-MEB-000 .1112in 2.825mm
14967-MEB-000 .1122in 2.85mm
14968-MEB-000 .1132in 2.875mm
14969-MEB-000 .1142in 2.90mm
14970-MEB-000 .1152in 2.925mm
14971-MEB-000 .1161in 2.95mm
14972-MEB-000 .1171in 2.975mm
14973-MEB-000 .1181in 3.00mm
I just measured the exhausts... one is 2.25 one is 2.30... which are rights and which are lefts?
You tell me, you should be able to swap shims depending on what side they came out of.
Sorry I meant left vs. right. Honda said what the formula was, they said you needed to know the stock sizes. I'm trying to avoid putting the cam back in and then having to switch the shims... If it has to come to that I will but I wanted to see if anybody had an easier way.
Here are the equations I came up with...
Intakes:
A=(.004-.006)+1.70
A=(.004-.006)+1.75
Exhaust:
A=(.009-.011)+2.25
A=(.012-.011)+2.30
Are those correct? What size shims does this tell me I need... I've never done this before so I'm kind of foggy on what to do.
How do you know which side they came out? There is no stock size shim all the motors are different.
For your top one you can take the 1.70 and put it where the 1.75 was. that will get you in spec. Then you need a 1.65.
Wait, I already stated that in my previous post. :cry:
The 2.25 you need a 2.20
The 2.30 you need a 2.325
This is assuming you have them in the correct side.
I don't think I have a 2.325... But I'm going to go try. Thanks for your help TJ!!! hope I get this right... I'll have to re-shim anyways once I ge to 0 clearance from the HotCam... (most people do)
I had to take my cam off and then put it back on about 3 times because I mixed the shims up. The numbers were wore off so I had to mesure them with my verniers. Make sure your cam chain is tight, if its not your mesurment will be off because the left side cam bearing has a small amount of play in it. Also that black coating on your cam loabs will wear off, its just there to help the cam brake in.
Write down the thickness of each shim and what position it is in (l-ex , r-in, etc.). If you ever have to re-shim it will definitely save you some work.
You're killin' me.
If you have .004 clearance and you need .006 look at what shim you have and go down 2 sizes because each shim is in .001 increments.
If you have .012 and need .011 go up 1 shim #
Me fix it!!! Yay! Now how in the hell do i get the valve cover bolts back in????????????? They just wont go in!!! It makes no sense. Agh I'm going to have to do this all over again after 30 mins of riding. :cry:
