ttr 90
i looked under my shifter on 90 and their wasnt a oil drain bolt and obviously there has to be one if any knos wat i should do thatd be great
I asume you mean that you cant find it on the bottom of the motor and not that its missing and there is no oil in there.
The oil drain bolt is on the shifter side as you said. It does not go out the bottom but rather out the side of the bottom of the motor if that makes any sence. It dosn't come out straight down but horizontal. That is the one to look for. Hope that helps.
