FCR + K&N Jet kit?
Well I've been lured over to the dark side and picked up an FCR 39 for my 03 S. Bought the K&N jet kit that came with a new needle and main jets. The kit recommends a 135 main jet for sea level. This doesn't seem correct. Is this the same needle that comes in the JD kit? Can I run a 165 main jet with needle or should I just get the JD kit?
Thanks
it is not the same as the JD kit.
the kn kit is the same and the dynojet kit.the dynojet kit for the fcr does not work.
all the references you see her eon the dynojet kit are for the S model carb.
