Dwight Rudder's tip for break draggers
One of Dwight Rudders tips (see his off road riding techniques on TT) was to use a stiffer rear brake pedal spring to minimize brake dragging in the woods. Me being a brag dragger of sorts (in the higher mileage tight stuff) I thought I would give it a try and used a really stiff old 2-stoke expansion chamber spring. THIS REALLY WORKS! My brakes were not cooked and your foot is strong enough to overcome the spring when needed - you get use to it fast, nice tip, thanks Dwight! :cry: :cry: :cry:
MSTex
Keep your pivot bolt well greased, check those o'rings. You'll wear the bushing in the lever real quick.
Good tip. Thanks.
I wore the stock rear pads out in 30 miles on my te-250. I have never had a set go that fast! Most last like 200-300 miles in the stuff I ride in. All I did to stop the wear was adjust the brake pedel to master cylender so I had to push the pedel further to make the brakes work. Pads are holding up real well now.
holy crap! what are you riding in? wet cement mixed with grinding paste? i've put 1 set of pads in my ktm in 8000 miles of fairly severe off-road, enduro and scrambles.
mw
