In search of very soft fork springs for 04 CRF450R
Would anyone want to swap an 04 CRF450R stock fork springs for a much softer springs for a 140lbs guy? I need softer springs.
Are you sure those will work with the 04 450 forks?
Can someone confirm this?
I have some .43s or .44s that I will trade for stock 04 springs. Both sets are stock honda from 00 and 01 CR250s. I couldn't use them because I am not a light guy.
james28210@yahoo.com
This is what I got from MX-Tech:
It seems like it's a perfect match. Also, I can use a stock rear shock on the 04 CRF250R and put it on my 450 too.
04 CRF450R
Your stock fork spring rate is.....47kg/mm
Your stock shock spring rate is....5.5kg/mm
Your recommended shock spring rate is....4.972kg/mm
Your recommended fork spring rate is....0.41108kg/mm
Your fork spring series is....43495xx
Your shock spring series is....mxtxx/50
01 CR250R
Your stock fork spring rate is.....44kg/mm
Your stock shock spring rate is....4.9kg/mm
Your recommended shock spring rate is....4.48kg/mm
Your recommended fork spring rate is....0.3969kg/mm
04 CRF250R
Your fork spring series is....43395xx
Yes, they work, I can confirm it. I am running 03 CRF450 springs in my 01 CR250, front and back. I got those from a 150lb guy who put my 01 CR springs on his 450.
They are all interchangeable from 2000-2004 without a doubt.
Looks like the .43s are the closest but still not .41. Let me know.
James if you have an interest in buying '04 springs - let me know. I have a stock .47 set with 10-12 hours on them.
