RUNS HOT BACK FIRES ON DECEL *DELETED*
turn the idle speed up and the bike should idle better.
on mine, if the idle speed is set too low it will die when I turn off the choke.
If your hot start is sticking it lets air into the carb. This makes it run lean. Running hot, backfiring on decel and hanging idls are classic signs of the carb being lean. Make sure your hot start is not sticking and you don't have any other air leaks. This should fix the problem.
I've had those exact symptoms twice and both times it was too much air (once my air/fuel screw fell out and the other I forgot to tighten the clamp on the hose from the air box to the carb).
