atc125 oil leak!
i have a atc125 and it has a oil leak.its a small leak that drips about 20 times every 30 minutes its on the right side case cover at the bottem between the two bolts, one already been rethreaded with a larger bolt and the other is on the verge of stripping because it is so tight.....What can i do to fix the leak with out takin the side cover off. is there any lubericants that will stop the leak???? :cry:
NO! NO! NO! :cry: :cry: :cry:
there is never an easy solution to that kind of problems.
just take it a part and fix it the right way first time, instead of trying several times without any luck.
