Help on Carb
1991 XR 250L, we took the carb off to clean the jets etc; Put it all back together and bike idled better than before, but it now has an off idle bog that's pretty bad. What do you think would cause this.We didn't change any of the jets or the fuel screw. I'm sure some off idle bog is expected,but the rider of this bike says it's much worse!
thanks
Does that carb have an accelerator pump? If so, you may have torn it or poked a small hole in it when you were disassembling/reassembling the carb. I did that once and got a terrible off-idle bog. Larry
