need XR200/250 engine dimensions for a MX conversion
lenght, width and hight. i dont want to get a 125 and cut the frame if i could use a 250 with a bigger and flater frame, maybe 500 also. dims would helo out alot befor i buy and screw myself over. im guessing i should use the stock xr carb and full electronics too.
ok anyone? :cry:........ i just need how tall the engine is if ya have a one just meashure it please i dont got an engine yet so id just like to know so i cna decide what size engine i want. thank you
I have an old bike mag that had an article about a CR/XR conversion. The author said the best way to go is to use the bottom frame cradle from the XR frame; makes life much easier not having to build motor mounts.
Plus I remember measuring my motor vs a CR500 motor and the XR motor is quite a bit taller and IIRC it was too tall to fit in the CR frame at all without modification.
