520 vs 525 compression ratio?
can I put a 520 piston in my 525 sx to lower the compression ratio? it is harerd to keep it from stalling when in tight trails compared to my friends 2001 520sx
The compression ratio is the same in both motors 11:1 You'll need to add weight to the crank to stop the stalling I have 2 different weights avalible if your interested. I'm guessing you have an '03? They have 40oz less crankweight than the 520's had.
I all ready have the 4k3a stator & flywheel , so all I need to do is get a crank out of a 520 and then it will be basically the same then?
