How easy is it to change fork springs?
I need to change to a softer springs on my 04 KTM125SX.
How easy is it to do?
- remove the forks.
- remove the top cap
- remove the nut under that cap located inside the spring?
is the installation the reverse?
It's fairly easy and basically the steps you mentioned. One tip though, loosen the top triple clamp bolts, then loosen the fork cap while the bottom clamp is still tight. Makes it much easier to remove them once the forks are off. I'd probably put some fresh oil in and measure the oil height to make sure they are consistent. Good luck!
