95 XR250 shifting issues
My shifter seems to not be returning to the middle spot after shifts. It shifts fine if you bring it back to the middle then make your shift but it wont go back on its own. It was fine till I took the shifter off the splines to reposition it and when I put it back on I had this problem. All i really did was tap the shifter back on with a wrench. Does anyone know what I did or how to go about fixing it?
It may be your return spring. It's on the opposite side under the clutch basket. A fairly easy fix if that's the problem. Check your manual before yo dig in though. Good luck.
