2005 CRF250 suspension upgrade
I can't speak the tech talk but, I need info in order to dial in my suspension for my weight(225lbs.). Do I need to make adjustments to the stock suspension or should I upgrade?
stock is ok , depending on your ability, you will have to order a 5.4 rated spring for the rear shock (race tech)
I have to disagree with sly on this one!
I am the same size as you and on my 450 as well as my 250 my suspension guy says that i need a 5.7 rear spring and the stock 250 fork springs might do it but i might need .47's
Since we are the same size i would say that these specs would apply to you as well. :cry:
You can save som money and buy 1 .49 fork spring which will average out to .47 since stock is .45. The Shock is 5.3 so 5.5 or 5.7 is a must. BTW don't forget to increase the rebound Dampening or you will be riding a pogo stick!
