KLX250...Jetting problem after mods.....HELPPPP
Hi ive read through heaps of threads here but still cant find the answer. Ive just removed the airbox lid and cut the mesh out of the air filter, but now the bike is running super lean. Ive read that i can adjust the needle jet but mine hasnt any adjustments. I also found from klx planet that i can replace the needle with p/n 16009-1912 which is adjustable but i want to make sure this can fit the 250 not just the 300. Can replacing the jets also fix the problem?? Whats the simplest way now to richen my bike up?? Please save me!! thanks :cry:
You must have a CA model. You must change the needle to the 49 state needle or it will run horribly lean.
Was there a "California Model" for the KLX250's??
If you can't change the position of the clip on the needle, get either the DynoJet kit or the non-Calif. needle.
Ride on
Brewster
