Det. Picture of 450X from Intermot exhib. in Munich
450x in Munich
You can click than on pictures from page to have better resolution.
You can note: stock glide plate, bigger radiators, bigger ignition carter cover (ie stator with lights), different clutch cable routing at engine side, fuel petcock with reserve, side air filter opening (as 250x), mod. clutch cover, thermostatic valve out of water pump,..........
Nice pics. Looks like the ignition cover is aluminum and check out the water pump cover, totally different. The skid plate looks cool and I'm sure it comes stock to cover the overflow tank.
That header sticks W-A-Y out though, almost like a 2 stroke.
Looks like they changed the hookup of the clutch. Different fill location for the trans fluid. I can't see the electric starter. What happened to the side airbox entrance. Looks cool.
tranny oil fill plug is relocated and the clutch cover is more manly...a hit from the brake wont poke a hole in it.
thermostat housing casted in case...
Looks good...wonder how much smog BS is on it.
