Spring rate question.
Wondering your thoughts on changing spring rates with the new shocks and forks that are so adjustable. Can you go up one or two steps on spring rate and still use the stock valving? Specifically thinking about KTMs. It seems like the rebound could be increased for the increased spring rate and the compression could be decreased if needed. Thanks for your info.
