04 forks question
I made the pvc adapter to hold the damper still while pulling the base valve out. for some reason 1" schedule 40 pipe's inside diameter is not large enough to slip over the hollow tube inside the fork so it can grab the 4 prongs.
Then using 1 - 1/2 pvc it's inside diameter is too large and it doesnt engage the 4 prongs that the adapter is supposed to grab onto.
Is anyone using something different to hold the damper on 04's?
