hey there jd ??????
Hi your needles are marked for high elev-hot/low elev-cold what would be the best set up me that rides from 1400-10,000 and coming into winter for the 02 crf450????
thanx jd
Use the recommended jetting specification in the kit for 3000-6000ft riding conditions. This will be a little lean at 1400ft and richer than needed to 10,000ft. Adjust the fuel screw leaner at the highest elevations.
The other choice is to use the jetting instructions in the kit for the range you will spend most of the time riding each day.
Thanks,
James
