HELP!! Choke lever comes up while running.. Will not stay off
Someone please tell what to do about my choke lever coming up on the bike while riding?? It is very loose. Is there an upgrade or a rebuild kit available??? Please HELP.. I had to tie it down with plastic ties.
there is a little metal bracket tat has akind of a stop in it,
maybe the screw is loose?
There is a little metal plate that clamps over the choke lever and is held on with a single screw. The metal plate has 3 holes in it for choke detent positions. By the time I figured out I had a problem, my entire plate and screw had fallen off. If yours is still there, take the plate off, clean everything and lube with water proof grease then reassemble and tighten the screw. If not, you can get the plate and screw through the online OEM parts sites like ronnies :cry:.
Thanks for all your help.. I pulled the carb out and well the screw was loose but I have some issues with the plate and return spring.. Looks like rebuild time.. YeeHaaaa!!! :cry:
