Hours and Odo Missing - EXC Speedo Display Problem
I am having a problem with the opperation of the speedo on my 03 450EXC (UK) - the display wont revert to the hours display that the manual claims will appear when the bike is stationary (and running I guess). The problem is doubled as I would also like to view the odo display missing as well and can only be turned on by holding down the mode button for 3 seconds when the display is showing the engine hours, which as I've just explained, is missing. I have tried disconnecting all the wire that lead to the display and removed the battery, but no joy :cry:.
Has any one had experiance with problems like these or any idea how i can sort it out?
Many Thanks
James
If your odo will only turn on when you push the mode button, not by just rotating the front wheel, than canucklehead's answer is right on.
