kfx 400 jetting??
I have a 03 kfx 400. I have installed the pro design air filter adapter with a clamp on K&N, removed the screen in the intake hose, and took the air box lid off. I am running the stock exhaust. I have tried many different sizes of jets from a 150 to a 180 and they all seem to run the same, but my plug is still kinda white. Elevations is 1600. what size of main do you recomend for my setup.
Try moving the carburetor needle clip down 1 step to lift the needle and run a #165 main jet. You should feel and improvement in the mid-throttle range and the top should rev out well.
James
