Enclosed Trailers ?
This may seem stupid but has anyone ever made one out of a regular flat bed ? I Already have a small 4x8 trailer and would love to make it a enclosed set-up . I know i could frame it up and fiberglass it but looking for suggestion or anyone's 2 cents ..thanks
That might work. Most trailers you get now though are aluminum sides/roof with a steel frame or aluminum. If done right you could prolly built a pretty nice set up off the flat bed. Also could be time consuming. You would need to build a frame off of what you have for the sides and roof and then coat all that with some aluminum sides. Maybe some plywood to coat the inside of it. Good luck if you go for it but compare the time/labor asspect of it with just buying an already enclosed trailer. I thought about building one but decided to just go buy one.
Sell the flat trailer and use the procedes as a down pament on a factory built enclosed trailer!!!!
You will be much happier and safer.
