KFX 400 Valve adjust
Hey guys, I have a question about the valve adjustment on a 2003 KFX 400. I know what the clearences are, however I'm not sure which timing mark to line it up with @ TDC. Also is this bike a "wet" ignition so that I'll have to drain the oil before I pull the case off? Or does the little site hole work effectively(can I see the marks)? If anyone has the process outlined, it would be greatly appreciated. I'm assuming it's relatively the same as the KLX 400 adjustment. TIA
