using brake in wheelies *DELETED*
no it can not pull you backwards it will still pull you down even if you are before 12 oclock,-------it is a good drill to know how to dragg the brake slightly while doing a wheelie and to be able to keep a constant speed and to keep it straight up and down or even alittle before 12 to practice control and ballence.-------it is just a law of physics--it is a vehicle in motion and the dragg forces of the brake will always bring you down in the same direction as long is there is rear wheel traction--it dosent matter at what point you are wheather it is 10 oclock or 12 oclock possition.
