Burned --- Almost There
Burned,
It took a while, but I found and installed your jet list for my KLX 400 With the FSW-FCR 39 conversion.
155 main
EMM needle
4th clip
38 pilot jet
5/8 turn pilot air screw (under bell mouth)
2 turns fuel screw
All I can say is WOW!!!
Runs a lot better. I still have a bog when I snap the throttle at a crawl. Nothing like it was but still not right. Seems to get better as I open the fuel screw to about 3.5 any ideas?
pump squirts about 2 sec from what I remember before I had to rinse my eye. :cry:
Could 2 sec be to long causing a rich stumble?
Thanks
Don
2 seconds is a little long.get it down to 1-1.5 seconds.
how does it idle?
when you snap the throttle does the idle hang then come down?go low then come back?
Burned,
Idle seems good best at 2-2.5 turns out.
How do you take the pump down to 1-1.5 sec?
I snap the throttle and it drops low like it's going to die for about 1 sec then it fly's.
Don
