drz125 shock
does anybody know a rear shock that will
soak up the jumps better.I way about
75 pounds so the shocks are pretty tuff
If you want to spend the money, you can get an adjustable shock off of a kx 80 85 100, or rm 80 85 100. That can get expensive. You might just try loosening up the rear spring adjuster to give you more rear spring. The 2 threaded rings that compress your rear spring, you want to use a hammer and a punch to spin those to the top of the shock. This will lower your seat height a little bit, but it will also take some preload off the spring, which will help you.
You could also call BBR, and see if they can't find you a sping about the right size that is less stiff.
Most of us have a problem with the springs being too light!
