04 CRF450 Jetting, with JD Jetting Kit
Dear James,
I was wondering what you thought about this jetting for my bike under these conditions....Stock bike, at 4200FT Elevation, at around 40 to 60 degrees. I have the Blue needle #2 with a 178 main?
I also had a question on how long the duration should be on the Accel pump, I have a P-38 Lightining, and want to make sure I am taking full advantage of it, or if it is making things worse. Thank You! :cry:
__________.:2004 CRF450:.__________
<ul type="square">[*]Fastway Accesories....Cable Clip, Case Saver, Clutch Bracket, F3 Footpegs, and Axle Blocks.
[*]Works Connection Skid Plate, Engine Gaurds, Frame Gaurds, Brake Caliper Gaurd, Rad Braces, and Anodized Goodies.
[*]Trick MX Parts ~ Anodized Goodies.
[*]Factory Connection - 1.76Kg Pressure Springs, and Oil Lock Collars.
[*]ASV Rotator Clamp
[*]Renthal--> "MC Bend" Fat Bars, and 49T Rear Sprocket
[*].:MX Bonz:. 1 1\8" Bar Clamps, and Sure-Lok Rim Lock Hardware
[*]LightSpeed Carbon Fiber Fork Wraps
[*]Tach/Hour Meter
[*]Polished Side Cases
[*]Racetemp Engine Thermometers
[*]Nology Hot-Wire
[*]SRC - 1.6kg/cm2 Rad Cap
[*]SDG Complete, High Foam Seat
[*]Fuel Line Mod
[*]Zip-Ty Fuel Mixture Screw
[*]JD Jetting Kit
[*]Factory R&D P-38 Lighting
[*]AirBox Mod
[*]Back-Fire Screen Mod
[*]Storm Link
[*]Twin-Air Air Filter
[*]D.I.D ERT Gold Chain
[*]13-49 Gearing
Don't Hesitate Accelerate!!!! :cry:
____________________________________
The setting sound good. I would compare the standard settings that came with the kit for 3000-6000ft (red #4 and #175MJ).
I don't know how long the duration will be with P-38 when snapping the throttle open. It usually is a fraction of a second.
James
Thanks James, I'll give the red needle a try!
BTW, not to say you didn't help me with the Squirt Duration, but I was looking for what the Squirt was suppose to be, like is there a standard time (say .3/sec) or is it different for different altitudes, and temperatures?
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]JD Jetting Kit
[*]AirBox Mod
[*]Storm Link
[*]13-49 Gearing
There isn't a right or wrong pump duration. It needs to squirt "something" (~.1 second or more), but more than 1 second is spending fuel unneccessarily. Repeated throttle pumping can cause over-rich conditions and flooding more often with a longer pump flow.
James
Thanks for your advise, I'll time the duration of the squirt and go from there.
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]JD Jetting Kit
[*]AirBox Mod
[*]Storm Link
[*]13-49 Gearing
