yz426 swingarm....
i did a search on swingarm and this is what i have found out
matt96xr6 mentioned that;
"98-01 use the same rear swingarm, shock, linkage and suspension out back. 02-04 use a different setup. The swingarm bolts according to Yamaha is 1mm larger at the pivot point on the 02-04 bikes from the 98-01 bikes. The shock is also 5mm longer on the 02-04 bikes"
so it will bolt it up fine.
:cry:
hmmm, i am not sure myself. but if you open up the 04 yz450 swingarm part diagram and compare with the 05, i am sure you find the answer. unfortunately, theres no parts update from the yamaha website.
if 05 uses the same pivot shaft and linkage, my guess is they will fit nicely.
hope someone out there with the 05 can help..
