TT-R 250 clutch issue?
Not sure if this is a problem or not. When I put the bike in 1st gear, the clutch is dragging. It doesn't disengage all the way. With the rear wheel off the ground, and the clutch lever pulled in, the wheel continues to spin. Are all the TT-R 250's like this? The clutch does NOT slip. I've tried adjusting it but no change. 😢
Normal. Both my wr and my ttr do that. IN gear, clutch in, and the wheel will spin, when it is on a lift. Must have something to do with not having any weight on the back wheel, and the clutch letting enough power though to drive the wheel.
