1984 XR250R
I've just rebuilt an 84 XR250R. I've read that Honda
stock jetting causes it to run hot. Does anyone have
any experience with this model? I have the stock jets
installed 108 main and 105 secondary.
Thanks
I've had decent luck with raising both needles 1 position and going up one size on the primary main. I left the secondary main alone because I'm not at full throttle all that much.
Basically you just want to get it as rich as you can where the bike still runs well.
Cool, I'll give it a shot. But first I have to fix an oil leak out of the counter shaft. I replaced the seal while I
had the case split but I must of nicked it while putting it
together. I just hope I dont have to split the case to fix it.
ok i have the specs for the 200 and 250 carb
84-85 xr200r
primary carb 98
secondary 95 for 1984...98 for 1985
slow jet 42
initial pilot screw...1 3/8 for 1984...1 1/8 for 1985
needle jet clip position from top
primary carb 4th groove secondary 3rd groove
float level 18mm (0.71 in)
idle speed 1,300 +- 100 rpm
84-85 xr 250r
main jet
primary 108
secondary 105 1984....98 1985
slow jet 45
initial pilot screw opening...1984 1 1/4 turns...1985 one full turn
needle jet clip position from top..primary 2nd groove...secondary 2nd groove
idle speed..1,300 +- 100 rpm
All specs per clymers manual
hopes this helps guys...i dnt remember what i have them set to in my bike but when i clean the carbs i will post which jets i have in there
I just bought one of these.  Removed the needle from the 2nd carb and the clip was in the top position.  I moved it to the middle position, which is the 3rd position.  So it that stock?  I don't know what position the 1st needle is in (yet).
