First trail ride since 1989
...Bought a nice 2000 DR-Z 400S last weekend, and took it out on some local trails today. Wow - I thought I was gonna DIE. Obvious changes needed are gearing - several times the engine tried to stall negotiating tight turns or obstacles. Tires (Trailwings) weren't too bad, the front tried to wash a bit but reading the posts on this board may prompt me to replace them.
All in all pretty enjoyable - but one thought keeps running through my mind. Is there any way to shave a BUNCH of weight off of this beast? I may end up trading for a non-street-legal smoker just to save my aching muscles!
Tony
Since it still has deathwings I take it its fairly stock.
Remove...
-Bar Ends
-One mirror
-Chain Guard
-Smog Canister (CA Model)
-Rear footpegs
-Heavy stock front light assembly (Get an acerbis or UFO)
-Rear Light Assembly can be trimmed down
-Stock Exhaust is heavy compared to aftermarket
To shave way more....
Remove all the E start items and battery and get a kick kit. I did this to mine saved 10 lbs or so.
Safety things to remove / bypass for safety....
-Clutch Switch
-Kickstand switch
You can get rid of even more weight. Just all about how far you are willing to go. 😢
Thanks. I have done the clutch switch and kickstand switch, as well as the chain guard. I know a hunk of weight is in the exhaust but $500 is mighty steep! I had planned (if I keep it) to lose the metal fuel tank.
Keeping all the doo-dads I can buy in mind, what would be a realistic weight figure for this bike to arrive at?
Thanks
