Is the XR400 frame a older CR125 frame?
I was told this and I am looking to verify if the XR400 frame is an older CR125R frame 92~94' I was at a track (closed now) in So. Cal. and a guy rode up on a XR400 with a gas tank with radiator shrowds. Had a narrow bracket that went between them (bolted where they should have bolted to the radiators) and the bracket was held to the frame with a 'U' bolt. Looked real cool. You would think it was a MX bike till you stared looking close....I ask and he said, it was a tank off an older CR125.
No its a different frame. The CR doesnt have the oil reservoir in the frame and the subframe is definitely different.
However that doesnt preclude a CR125 tank from fitting on the XR4.
