Compression check specifications for DRZ400S
Does anyone know what the Suzuki factory spec (or allowable range)is for the DRZ400S? I'd like to do a compression check to verify the condition of the top end.
Thanks,
Michael.
gotta do a leak donw like bronco has said.the auto decomp seems to make each bike vary a bunch.battery condition directly affects the function of the decomp.if you have a weak battery the decomp stays engaged longer resulting in low readings.
