Jetting after coast enrichener removed
It's time to remove the octopus from the side of my carb.I am looking for sugestions for the jetting.
01 kicker,lid off,full yosh,jd jet kit,alt 6000-8000.
Thanks for any tips :cry:
when I took off my CE I went to this setting.
165 main
40 pilot (was 38 at first, switched to 40)
PAS 5/8 turn out (pilot air screw)
JD blue needle 3rd clip
fuel screw 2.5 turns out
This is good for me at lower altitudes, since you are at higher altitude you may want to lean it some.
burned would know better, but thats my setup.
You'll need to wait for burned to check in, but removing the CE generally means to go to a 38 pilot jet.
keep in mind I have the stock exhaust and ride from sea level to about 8,000 ft. so this is the best compromise so that I don't have to change jetting for each area. If I did most riding at sea level I'd go to a larger main.
155 main
40 pilot
2-2.5 turns fuel screw
1/2 turn pilot air screw
JD blue on clip 3
airbox lid gone
Had some hesitation with the 38 pilot then switched to 40 and it was GONE!
Thanks guys you both are real close to the same jetting.The great one(Burned) rides the same alt I do.If he dont chime in I will start with your set up :cry:
burned is a little busy today, but I'm sure he will answer as soon as he can.
