JD Jetting Kit; 172 main a problem?
I bought the JD jetting kit for my '05 450 EXC. The kit recommended--and comes with--a 172 main. The stock main is a 178. Is it OK to go down (lean) this far? Does the new needle richen things up that much? What about at full throttle when the needle is not so much a factor? For the record, the bike ran quite well with the 178.
Riding conditions are sea level to about 3000', with temp. in the 60-80 F range.
Any help would be greatly appreciated.
Jeff
whatever came in the kit is what you need to run.i know it sounds odd but he knows what he is talking about.
Second that. Months of screwing around and experimenting with unsatisfactory results were solved instantly with JD's jet kit. JD is GOD 😢
