lookin 4 help ( top end tourque specs)
anyone help me i need to find torque specs for my ttr 225 how often am i gonna have to do this ring job??
the cylinder bolts are 10Nm(7.2ft.lbs) the cylinder headis 22Nm(16ft.lbs)that is for the 4 bolts on the top. the 2 bolts on the back of the head are20Nm(14ft.lbs) the cam sprocket bolt is 60Nm(43ft.lbs)the cam chain tensioner bolts are10Nm(7.2ft.lbs)the cap bolt for the cam chain tensioner is 7Nm(5ft.lbs) cylinder head side cover 7Nm(5.1ftlbs) and the valve covers are10 Nm(7.2ft.lbs) Hope this helps ya out. If I missed something and you not sure when you come across it let me know and I'll find it for ya.
