Stator rewind
I have a UK spec 2001 XR400, if I have the stator rewound do I need a different regulator or rectifier or can I just fit the new stator and then wack in a higher wattage bulb???
All I am after doing is getting more power out of the existing head light so I can ride at night.
you should not require a different regulator, the reg is able to handle the extra load. up to about 90w without a problem.
on the 250 i have been using the stock reg w/80w output for several yrs without a glitch.
stu
