Mild gear noise after kickstart install
I just installed the kickstart kit on an '03 S. Everything works fine (2 kicks = vroom), but I'm getting a mild gear noise when the engine idles. It's not loud, but it's more noise. Is it normal?
I took everything apart and I don't see any evidence of anything rubbing. I think the noise comes from the kickstart drive and idle gear working together. They make a mild noise when I rotate them by hand.
I quadruple-checked the install and everything looks as it should be. I put the idle gear retainer back in, so that's not the problem.
did oyu put the retainer on in the right orientation.if its worng it will just touch the clutch basket and cuase a noise.
I'm not familiar with the kickstart kit....are the new gears spur gears or helical? That makes a big difference in terms of noise.
