Aftermarket pipe rubbing your Spring on jumps?
I've got a Pro Circuit T-4 can with half the rear pipe that comes with it. It just slides into the stock front half pipe with no collar? It's rubbing my yellow paint off the spring around the area that is pre-curved (to avoid the spring). Anyone else have this problem?
Trent
FWIW, I have seen this on several bikes, including both my brother's bikes. It usually is a result of a crash that slightly bent the exhaust enough to touch the spring. We usually just bend it back!! Hope this helps :cry:
Bend your subframe back, or else you shock will rub a hole through the pipe like it did mine.
When I first put on my Big Gun exhaust it rubbed on my spring . Took it back off and the yellow paint told me where to whack it with a hammer :cry:. Easy fix .
James
