525sx back fires
My 525 back fires when the bike is cold and warm. Will the mixture control screw stop it and if so which way should i turn it?
Also check for exhaust leaks. My 520EXC and both 450SX's popped until I used some high temp silicone on the header connections.
If it's stock. A JD kit works wonders.
If it's been jetted... I'd say set the throttle pump for a one second squirt. Otherwise it's still a bit too rich off of a hard throttle.
Really though... if the jetting is stock... change it FIRST.
Mine did the same thing, even with the JD jetting kit. Sealing the header with high temp silicone eliminated the problem. Pull the header from the cylinder, apply a nice thick bead of silicone to the flanges and push the header back on. This should solve your problem.
