TT-R125L + BBR engine oils
I've been reading alot online lately about engine oils for 4-stroke motorcycles.
Do the non-motocross 4-strokes demand as high a grade of oil as the motoX'ers?
My TT-R125LE has airbox mods, high-flow air cleaner, big bore carb/throttle, big-bore engine kit, high-flow exhaust pipe, and HD clutch springs; all by BBR.
What oils are those of you using who have BBR 150CC big bore kits installed? Do any of you run high-grade automotive oils, or others??
If so, do you have problems with clutch slippage, etc?
I just saw that Yamaha's price for a bottle of Yamalube 4 is about $45.00/quart. That could get pricey, quick. :cry:
Any suggestions for a HIGH QUALITY oil that will not be "an arm and leg", to change routinely?
Thanks, Matt
Any oil that carries the Japanese "MA" rating will be just fine.
In my shop we use Castrol ActEvo as our standard non-synthetic oil
for most customer oil changes. It should sell for $3.95 /liter.
Really, any name brand motorcycle oil will be fine. I suggest
you stay away from automotive oil. The newest car oil is being
formulated more for fuel efficiency than outright lubrication and
and may not fully protect a motorcycle engine.
I use Spectro Golden 4 which is a semi synthetic. It made the shifts smoother than with the Mobile1 15w50. I also tried Motorex but it dirtied up really quick and Maxima from what I have seen is crap oil bottled as HP in a bottle, so I stay away from it.
im using ams 5-30 synthetice and havent had a problem but that yama lube holy thats expensive
