XR50 Carb cap
You need to unscrew the cap from the carb then disconnect the cable from the slide inorder to pull the cable out.
Be carefull not to lose the clip that holds the needle in. You will see what I mean once you remove the cable/spring.
:cry:
I did that and have the complete assm. in my hand, but cant see how to remove the cable housing from the carb cap.I bought pro taper bar kit and have new cables,I just cant seem to get that cap away from fact cable?????? Im new here, thanx for the help....ps this is a 2003 XR50
Alright here's what you do:
1. Grab the cable housing with pliers and RIP it out of the metal elbow.
2. Cut the bend out of the elbow so that there is no bend.
3. Grab the bottom half with pliers and drill a hole JUST big enough for the new cable to fit in DO NOT DRILL ALL THE WAY THROUGH. This will stop the cable from being pulled into the carb.
4. Put the cable in your new hole and CRIMP it tight with pliers. Now wrap it with electrical tape and have fun...
I bought the Pro-Taper kit as well, and your new throttle cable should have a new carb cap already installed on it. There should be no need to remove the old carb cap from the stock cable.
