A.P Linkage, Need Some Info
Guys, i need to know how your linkage operates normally. I had my carb apart this weekend for general P.M and noticed that when i held the slide wide open, the linkage did not go all the way down to the metal stop moulded in the side of the carb housing.
I have not messed with this linkage and thusly i do not know what normal operation looks like. I took care of my bog with lj's and diaphragms. I can advnace the linkage manually with my finger to the stop with no resistance and it still discharges fuel.
Examining the linkage, it seems pretty simple. Two opposing springs and a actuator rod. I checked the rod, it was straight. I checked for gunk in the pivot of the arm, it was clean.
Before i go any further, i would like to get some advice from someone that knows what a properly operating unit should do. I do not want to create a problem if one does not exist, know what i mean???
