ttr 90 kick start only works half the time..???
I have a 2000 ttr90 and this kick start will free wheel half the time, you can lay the bike on it's side and it will pick up inside and work. Anyone have the cure for this problem? :cry:
You need to adjust the clutch. The kickstarter works thru the clutch. The clutches in these little bikes take a heck of a lot of abuse from the kids doing 3rd gear starts.
On the left hand side of the engine behind the flywheel housing there is a philips head set screw with a lock nut on it. Loosen the nut and turn the screw in and out a little. It will probably have to be turned in. When you feel it touch something solid turn it back about 1/8 turn and retighten the nut. That should fix the problem.
Once the clutch starts wearing it seems to keep on going. I am always adjusting my kids clutch. Ya gotta teach them NOT to start in 3rd gear. :cry:
