X Tail Light
Is the X tail light on a closed loop circuit with the head light? Just the other day I realized that none of the LED's in my tail light were working (not that big of a deal to me) and I dont know how long they have been out. Is this because I removed the headlight? Just curious, thanks!
Rear lights will still work when you remove the headlight.
Probably connection issue as LEDs last for ever (well allmost)
Ok, knowing that I will pull off the lft side number plate and see what happened.... Thanks!
when i got my 04 crf250x the rear taillight leds were never connected so i simply tacked that cable onto another one that was behind the left rear plate. i think its black wire and now it works great
do you still have the battery connected if you didnt you may have burned out the voltage regulator i read up on this in the feb 2005 dirt bike mag
