Stainless or Titanium
I am considering going with High Grade Titanium Valves rather than the Stainless Steel "Kibble White" Valves on my '04 CRF450. I was wondering who has done that, and what they thought. I have also considered the price difference of the much more expensive Titanium Valves, but If your going to replace them, you might as well do it right. Any input on that would be greatly appreciated. Thanks! :cry:
__________.:2004 CRF450:.__________
<ul type="square">[*]Fastway Accesories....Cable Clip, Case Saver, Clutch Bracket, F3 Footpegs, and Axle Blocks.
[*]Works Connection Skid Plate, Engine Gaurds, Frame Gaurds, Brake Caliper Gaurd, Rad Braces, and Anodized Goodies.
[*]Trick MX Parts ~ Anodized Goodies.
[*]Factory Connection - 1.76Kg Pressure Springs, and Oil Lock Collars.
[*]ASV Rotator Clamp
[*]Renthal--> "MC Bend" Fat Bars, and 49T Rear Sprocket
[*].:MX Bonz:. 1 1\8" Bar Clamps, and Sure-Lok Rim Lock Hardware
[*]LightSpeed Carbon Fiber Fork Wraps
[*]Tach/Hour Meter
[*]Polished Side Cases
[*]Racetemp Engine Thermometers
[*]Nology Hot-Wire
[*]SRC - 1.6kg/cm2 Rad Cap
[*]SDG Complete, High Foam Seat
[*]Fuel Line Mod
[*]Zip-Ty Fuel Mixture Screw
[*]JD Jetting Kit
[*]Factory R&D P-38 Lighting
[*]AirBox Mod
[*]Back-Fire Screen Mod
[*]Storm Link
[*]Twin-Air Air Filter
[*]D.I.D ERT Gold Chain
[*]13-49 Gearing
Don't Hesitate Accelerate!!!! :cry:
____________________________________
Along with your question about which valves to use, what valve springs should be used? Should stock springs be used?
if you are going to install aftermarket titanium valves make sure that they have a casidiam coating or some kind of a hard coating im using a prapriorty coating that has a higher working temp than casidiam ,it wont mater how high of grade titanium you use if there not coated they wont last as long as the stock valves on the hard seats.
So would you sugest that I have pro-circuit do there nickle copper vale seat mods or ???? and does anybody else do that, and how expensive is it?
And finally,
so your saying that its not the valves that need to be fixxed, its the valve seats?
Thanks
Ryan
and what would this upgrade help?...Reed Valve Vs Titanium Valve..???
Reed valves? Were talking about 4 strokes. :cry:
Thanks for the input guys, but I too am wondering about which Seats to use (Stick with Stock or go with a Softer Copper or Nickel Seat like "yzfmxer" said), and if I should go with Harder Valve Springs (I'm thinking that would be a good idea especially for the 450). :cry:
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]JD Jetting Kit
[*]AirBox Mod
[*]Storm Link
[*]13-49 Gearing
go with the stainless valves and the heavyer intake springs puting in the special titanium valves and bronze seats are usaly used on the dirt trackers this is what i do on the big valve heads .you wont loose any performance with the stainless and they will last longer than the ti bronze set up Ron RHC
